engine on idle not working properly
hi
I have the following issue with my skoda2 tdi engine (CAYB):
- happens only after engine is warm (after a few miles)
- if any consumer is on (light, AC, etc..) engine seems to work fine
- there is also a strange noise behind the car (maybe fuel pump)
- i know the coolant fan does not work in stage1 - i did not get the time to change it (it's not a cheap piece)
- the other error i dont know what it means
thanks.
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 5J0 820 045 B    HW: 5J0 820 045 B
   Component: Climatic       12 0670
   Revision: 0003S 12
   VCID: 24419CD227AC953EDF5-8071
1 Fault Found:
00705 - Relay for Coolant Fan; Stage 1 (J279)
            009 - Open or Short to Ground
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R7 937 085 C    HW: 6R7 937 085 A
   Component: PQ25 BCM      H10 0017
   Revision: -5------    Serial number: 1002430301
   Coding: 64980B1808010040002800003E0A09C00000400F600000000000
   Shop #: WSC 13765 790 00051
   VCID: 428D3A4ADDF8BB0ECD9-8017
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3210
   Coding: 020000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3210
   Coding: 020000
   Subsystem 3 - Part No SW: 3T0 959 537 D    HW: 3T0 959 537 D
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
Replace the relay and see if it clears it
