gtb powered cars
Hi seems to be a few members here from the north wales area running GTB turbos, i'm soon to be fitting one to a mk4 golf, any of the members here be interested in showing me what i can expect? also close to buying a cg motorsports 666 series clutch, what clutch are you guys running?
cheers Nick
I'm not up there but running gtb2566vk turbo using sachs SRE clutch to keep all in check.
Spoke on FB briefly Jason last week and im still considering the cg smf kit, although i have seen xman has a kit capable of 400lb/ft on a dmf setup is that just going to shat itself with a lot of torque though?
Dmf will fail in no time running GTB power
Wouldnt consider running anywhere near 400lb/ft
Where in North Wales are you mate?
....and I'm still on a standard clutch and flywheel...  Xman setup ready to fit for when it does eventually die!
Hi mate i'm in wrexham, have spoke to x man about a dual mass setup cabable of 400lb/ft, seems to be a debate on whether a dual mass will last long term though. gtb2260 on a standard clutch! :o. What torque are you running?
I'm in Wrexham too pal. So you're welcome to have a look at mine when you want.
It pulled 356ftlbs on the last rolling road day. Yup I know, I can't quite believe it's lasting either! It won't die!!
Nice one, ill drop you a PM mate
