engine mount bolts and cam and crank seals
Iv purchased a cambelt kit, hydraulic tensioner and a water pump. I need to order a auxiliary belt and iv heard the engine mount bolts need changing. Anyone tell me the part number for these and how many I need. Is it only the one near the cambelt. Iv also seen on the net a kit that contains cam and crank seal. Is this a must change? Is it likely to cost me more in labour to have this done too or is it a simple joB. I personally haven't played with cambelts so I will be taking it to a garagE.
Managed to find out the bolt part numbers.
N90596906 x 2 - Bolt M10x55x32
N10209605 x 2 - Bolt M12x1.5x65
