Lower boost pipe (hard air pipe)
not that part i want.
thats off the intercooler, i want the part after the 90 turbo elbow down to that part.
I'm confused, the lower boost pipe, from the turbo to the intercooler
Or
From the intercooler up to the egr valve?
The bottom is basically a 90° silicone, into the pipe I posted and then another 90° silicone.
Which part from here?
Part number 3 i guess, but mine didn't look like that diagram, it was a hard pipe, that was vertical with a rubber 90 to the turbo
That diagram is from a golf ASZ engine. It's pretty much exactly the same apart from the S shape pipe number 4 is a 90° on the Fabia.
Number 3 you wanted is the part I listed above.
Sorry i mean number 4, the part after number 3
:D I have part 4 sitting in the bottom of my tool box. Iirc it's basically just a 90° silicone pipe, same as the rest.
How can you tell? I guess the diagrams would be similar
The part number should be 6Q0145822
So its that plastic one you need?
