VCDS Fault code - 00526
Bit of a dilema, MOT is due on the Roomster 14th April.
Fitted an Amundsen+ last weekend to the Roomy and during the course of j0hn and I blew a fuse or two :giggle:
All sorted now apart from the fault code below, which means that the ESP light is on on the dash and consequently a FAIL.
VCDS SCAN:
Saturday,11,April,2015,10:29:10:26358
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: TMBNG65J285059216   License Plate: R30BGT - 110415
Mileage: 166090km-103203mi   Repair Order:
Chassis Type: 5J (5J - Skoda Roomster (2006 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBN******************   Mileage: 166090km-103203miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 NR
   Component: 1,9l R4 EDC 0200SG  9134
   Coding: 00102
   Shop #: WSC 01234
   VCID: 74ECCCF344DDD9817A7-4AB4
   TMBNG65J285059216     SKZ7Z0H4700052
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 6R0-907-37x-ESP80.lbl
   Part No SW: 6Q0 907 379 AP    HW: 6Q0 907 379 AP
   Component: ESP 8.0 front   H03 0001
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0000284
   Shop #: WSC 73430 790 00000
   VCID: 0B1EB70F6923A6790BD-50E6
1 Fault Found:
00526 - Brake Light Switch (F)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 182
                    Mileage: 166099 km
                    Time Indication: 0
In my head 'open circuit' is usually a fuse (not had time to check all of these, and won't ahead of the morning of the MOT).
Is there anything else I can rule out (or more specifically j0hn) as I'm in Kent without the car until next weekend.
TIA
J5
First thing I would check for is a blown brake light bulb, they used to cause all sorts of false "brake light switch" errors on my old Alhambra - worth a look for the 10 seconds it would take
Should have written that those were checked when car was first scanned, but thanks for the input :thumbup:
brake light switch has two sets of contacts, 1 for the actual brake lights and the other for engine management, have had similar on swmbo's mk1 fabia vrs replace the brake light switch all is good, PITA to get to though,
if you blew a few fuses changing the radio get a job lot ready if you do the switch :)
How did you get on with the MOT? Hope you got it sorted. Wasn't the radio swap a straight unplug and plug in job?
It's not a fuse!! MOT is in 20 mins
Hope it's a "happy" birthday, J5
Any update,Jonny ?
Brake switch replaced at a massive cost of £8.50.
No change, fault still present :(.
Problem caused by LED bulbs in the brake lights!!
MOT all good for another year!!
Good news! These electronic systems are a pain, far too clever for their own good.
