1.9tdi ASV engine cutting out
I have but never experienced it on an engine before . So it took some tracking down .i ended sorting other problems and fault codes aswell along the way. Just hoping the smoke clears up once its on the road (I'm thinking the amount of times its cut out its just un burnd diesel sat in the cat and exhaust system ) if it doesn't then could be bad injector dripping maby or turbo?
Jim
Your other possibility would be oil in the intercooler. It's fairly easy to drain that by opening the lowest joint at the RHF arch.
Do you have to unbolt the intercooler? .i saw a youtube where someone drilled a small hole in the cooler plastic to drain it then put a small self tapper in to seal it .dont fancy that realy lol
Jim
Jim
I can't see why they did that. You might have to take the cooler out (that will depend on whether the elbows are part of the cooler or the pipework) but the youtuber is a self-confessed bodger.
Lol yes I did think that as well
Jim
Well started useing the octy alls going well except the osr brakes sticking so more work to do.i think the cables been over adjusted a tad and the return spring on the calipers a bit week . Great ..
Jim
Edited by jublybug
You can get additional return springs for the rear callipers.
Can you? Any pics of them and where they mount? Have you used em ?
Cheers jim
Yeah used them and they work very well. 991d666f3487d30108cff0fa365472b0.jpg
Ignore the dampers on the callipers lol
I'm I being stoooopid witch bits the spring you talk about?
Jim
The spring is the silver item above the round black bit.
Item number on eBay is 231533982638
I see now . These a factory mod job? Or aftermarket idea .cheers for the link
They were allegedly a factory mod.
Got the springs coming from tps £6 the pair ,had a look today and the cables free and calipers not to bad so worked it and backed adjustment a tad . ..
Jim
Well springs are on so well see how they get on .
They should work well. I had a sticking calliper on the rear fitted the springs and sorted it after freeing the calliper up first obviously lol.
Thanks for the tip seems to be ok after a run out tonight.
Happy motoring
