Air con not working
evening all, as above air con isn't working, can't here the compressor at all when inswitchbit on has been like it for the last year fuses all ok, may look at getting a second hand pump but is there any way to check if it's defo the pump I had it regassed but it made no difference
This happened to my car had a free check by ATS they said plenty of gas but your compressor is knackered, bought a second hand one and haven't fitted it yet. Lazy git i am.
About 2 years ago the aircon stopped working on mine - I bought a new compressor but the fault remained - had the gas level checked all ok -
I eventually found that the  wiring to the compressor had corroded and was creating a short - the wire went under the battery casing where water had gathered and caused the problem -
Maybe worth an electrical check before paying out for unnecessary .
Previously I found a broken wire at the same place as the load signal wire might be worth checking there first
