fitting militech lower grills
has anyone had problems fitting the milotech lower sports grills.
I have finally got em, they are all sprayed and looking good, but Damn they are a bugger to fit. Any one else had this prob?????
They dont just fit in like the others do they?
in fact modification to the bumper maybe required, any thoughts on the best way of doing this? and what if any glue or silicone has anyone used??
Oh and by the way extreme spoilers dont match up on the bolt holes to originals either, starting to wonder if chaving the octy was a good idea:(
I put one on a Superb, and it did need more silicone than they supplied. But, once there, its stayed solid for several thousand miles and survived a quick run at 143mph indicated.
Its worth the effort, just think of it as an investment !
thanks for the reply, since i posted i have sorted em out, they are finally fitted.
You were right by the way, not enough silicone sooooooo, i had a chat with some lads who are members of south west cruising, they **** up cars all the time, they adviced me NOT to use the stuff supplied and use sommat called Tiger seal instead, you can buy it pretty much color coded and its sole purpose in life is body kits and add on's etc.
Its around
Once stuck with Tiger seal it ain't coming off... ever......never.....
