retrofit mk60ec1 and PLA 2.0
Hi
Im retrofiting PLA 2.0 to my skoda but got promlem whith my ABS pump. My superb had MK60 pump and i had to replace whit MK60EC1 but i have problem to code the pump.
i tried this codes but not working:
863D6016092300FC611406EC901A0082340000
863D6016092300FC611406EC901A0082350000
863D6016092300FC611406EC901A0082000000
863D6016092300FC611406EC901A0000000000
original coding:
VIN: TMBBF73T199012981   License Plate: 08DSKODA
Mileage: 145410km-90353mi   Repair Order:
Chassis Type: 3T (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBF73T199012981   Mileage: 145410km-90353miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 JL    HW: 03L 906 022 GA
   Component: R4 2,0L EDC G001SG  5754
   Revision: 13H01---    Serial number:
   Coding: 0200072
   Shop #: WSC 00581 941 91570
   VCID: 78FFCC250B6714E157B-802D
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 3T0 907 379 A    HW: 3T0 907 379 A
   Component: ESP FRONT MK60      0102
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 35110 377 00999
   VCID: 3B7513297AD1FFF97A9-806E
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 M    HW: 3T0 907 044 M
   Component: Climatronic   122 0102
   Revision: 00003001
   Coding: 0018000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 3C771035B7DFF8C1733-8069
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 A    HW: 1K0 937 086 A
   Component: BCM PQ35  M+  020 0360
   Revision: 00020000
   Coding: 40990AB8D00508C040080084110081A405791BAE432081605C4040000000
   Shop #: WSC 00594 941 84491
   VCID: 2E532A7D79A31A51CD7-807B
   Subsystem 1 - Part No: 3T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 15070  22  0602
   Coding: 00DFB7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 070808 05  54  0402
   Coding: 0730ED
3 Faults Found:
00988 - Lamp for Brake Light; Right (M10)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 236
                    Mileage: 145111 km
                    Time Indication: 0
                    Date: 2009.05.25
                    Time: 19:30:56
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.70 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 238
                    Mileage: 145225 km
                    Time Indication: 0
                    Date: 2009.05.26
                    Time: 19:09:01
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00907 - Intervention load Management
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 145412 km
                    Time Indication: 0
                    Date: 2009.05.28
                    Time: 14:08:58
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.50 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655     HW: 3T0 959 655
   Component: J234__LAJ VW10 HI   1815
   Revision: 17013000    Serial number: 003CCPEN5SZS
   Coding: 0016714
   VCID: 7EF3DA3D29432AD11D7-802B
   Subsystem 1 - Serial number: 6333FTS616011978
   Subsystem 2 - Serial number: 6343FTS613641968
   Subsystem 3 - Serial number: 6353ETS6VC3DUVNP
   Subsystem 4 - Serial number: 6363ETS65O1DUVNP
   Subsystem 5 - Serial number: 6373JTS640JFUVNP
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0000531
   VCID: 76E3C21D01736291457-8023
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0011
   Coding: 00000128
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 840 D    HW: 3T2 920 840 D
   Component: KOMBI         H28 0024
   Coding: 110900
   Shop #: WSC 35703 895 00999
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
   VCID: 346738159F8F3081BB3-8061
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K088050674
   Coding: E9807F060002023303
   VCID: 356105115CF529898CD-8060
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H28 0024
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 A    HW: 7N0 959 793 A
   Component: TSG FA        H03 0190
   Revision:             Serial number: 0000100188239
   Coding: 011F0220D001121002
   VCID: 408F64C5D3379C212FB-8015
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 195    2301
   Revision: 00H15000
   VCID: 2A5B266D854B767111F-807F
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 A    HW: 7N0 959 792 A
   Component: TSG BF        H03 0190
   Revision:             Serial number: 0000100194040
   VCID: 3F8D6739AEC9E3D9561-806A
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3T0 035 156 B    HW: 3T0 035 156 B
   Component: BOLERO        006 0036
   Revision: 0A001001    Serial number: SKZ1Z3H8810988
   Coding: 050004000004
   VCID: 2D512D7174A56149F4D-8078
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-795.clb
   Part No SW: 7N0 959 795     HW: 7N0 959 795
   Component: TSG HL        H02 0190
   Revision:             Serial number: 0000100191793
   Coding: 010C00200001221002
   VCID: 0109A1C198BD5529605-8054
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794     HW: 7N0 959 795
   Component: TSG HR        H02 0190
   Revision:             Serial number: 0000100192165
   VCID: 55A1A5913CB509896CD-8000
End-------------------------(Elapsed Time: 02:06)--------------------------
new pump fitted:
Friday,01,May,2015,20:19:26:46175
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: TMBBF73T199012981   License Plate: 08SKODA
Mileage: 150690km-93634mi   Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBF73T199012981   Mileage: 150690km-93634miles
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
   Coding: 0200072
   VCID: 78FFCC250B6714E156F-802D
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Coding: 00000000000000000000000000000000000000
   Shop #: WSC 00028 028 00001
   VCID: 7BF5D329FA513FF93BD-802E
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
   Revision: 00003001
   Coding: 0018000000
   VCID: 3C771035B7DFF8C1727-8069
   Revision: 00020000
   Coding: 40990AB8D00508C040080080110081A405791BAE432081605C4040000000
   VCID: 2E532A7D79A31A51CC3-807B
   Coding: 00DFB7
   Coding: 0730ED
Address 10: Park/Steer Assist (J791)       Labels: 3T0-919-475-V2.clb
   Part No SW: 3T0 919 475 E    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0009
   Revision: --------    Serial number: 56231326201902
   Coding: 149001
   Shop #: WSC 35110 377 09999
   ASAM Dataset: EV_EPHVA2CAS46X0000 002001
   ROD: EV_EPHVA2CAS46X0000_SK12.rod
   VCID: 3F8D6739A6C9E3D9575-806A
2 Faults Found:
13637395 - Databus
          U1123 00 [009] - Received Error Message
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 150695 km
                    Date: 2015.05.01
                    Time: 00:12:19
13637399 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 150695 km
                    Date: 2015.05.01
                    Time: 00:12:19
   Coding: 0016714
   VCID: 7EF3DA3D29432AD11C3-802B
   Coding: 0000531
   VCID: 76E3C21D01736291443-8023
   Coding: 00000128
   Shop #: WSC 00000
   Coding: 110900
   VCID: 346738159F8F3081BA7-8061
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 160511F2003576
   Coding: 359303
   VCID: 34673815978F3081BA7-8061
   VCID: 408F64C5D3379C212EF-8015
   Revision: 00H15000
   VCID: 2A5B266D854B767110B-807F
2 Faults Found:
00778 - Steering Angle Sensor (G85)
            000 -  -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 150695 km
                    Time Indication: 0
                    Date: 2009.09.21
                    Time: 00:14:04
             Freeze Frame:
                    Battery Volts: 12.0 V
                        DD
                    Temperature: 23.0°C
                    Count: 9
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
01316 - ABS Control Module
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 150695 km
                    Time Indication: 0
                    Date: 2009.09.21
                    Time: 00:14:05
             Freeze Frame:
                    Voltage: 12.00 V
                        DD
                    Temperature: 23.0°C
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
   VCID: 3F8D6739AEC9E3D9575-806A
   Coding: 0D0004000004
   VCID: 2D512D7174A56149F59-8078
   VCID: 0109A1C198BD5529611-8054
   VCID: 55A1A5913CB509896D9-8000
End-------------------------(Elapsed Time: 02:18)--------------------------
Edited by bartireland
  • 3 months later...
Hello!
Maybe this will help you:
Adresa 03: ABS frâne (J104)       Eticheta: ROJ\1K0-907-379-60EC1F.clb
   Număr VAG SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Componenta: ESP MK60EC1   H30 0105
   Revizie: 00H30001
   Codare: 843D6016092300FE210B06E7901F0042350000
   Atelier: WSC 33361 790 00059
   VCID: 040DE7E587FECB014B3-8051
