Door Control Unit/ Data Bus Single-Wire Operation
Had the following error codes on vag com
01336 - Data Bus for Comfort System
        49-10 - No Communications - Intermittent
01336 - Shareware Version. To Decode all DTCs
        80-00 - Please Register/Activate
Changed the door control unit on drivers side (attached to window motor)
One fault has cleared but the other remains.
        80-00 - Single-Wire Operation
I was wondering what the significance of the second set of numbers after the fault code were, the 49-10 and 80-00. Do they give me more of a clue as to where to look next? The wiring seems fine, should I go round checking the other doors next?
Oh and superb mk 1, 1.9 diesel, 2007 in case that makes any difference.
  • 4 years later...
i expect youve sorted this but thr single wire issue was probably a break in one of the canbus wires between A pillar and door on drivers side.
