Airbag error and steering wheel controls out
My 2013 Superb just threw an airbag error and the buttons on the steering wheel and the horn have stopped working.  Wipers, indicators and cruise control are working normally.  I have plugged it into my VCDS and the following errors came up:
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__LD5 VW10 HI   2118
   Revision: 24019000    Serial number: 003LEP518A34
   Coding: 0017461
   Shop #: WSC 33361 790 00064
   VCID: C281600A9D734031B84-8097
   Subsystem 1 - Serial number: 6332MTS639520643
   Subsystem 2 - Serial number: 6342MTS639650643
   Subsystem 3 - Serial number: 6351HTS62PN0RBKJ
   Subsystem 4 - Serial number: 6361HTS6PBP0RBKR
   Subsystem 5 - Serial number: 63727TS6FGD4RBKR
   Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
            001 - Upper Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 43257 km
                    Time Indication: 0
                    Date: 2015.04.29
                    Time: 17:44:12
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Component: LENKS.MODUL   016 0140
   Revision: FF010041    Serial number: 20130319800687
   Coding: 1882140000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FEF9D4FA610BE4D19CC-80AB
1 Fault Found:
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 90
                    Mileage: 44012 km
                    Date: 2015.05.14
                    Time: 13:01:00
I have tried clearing them but they pop up again immediately.  I'm thinking it's the clock spring or a break in the wiring?
Any and all thoughts welcomed.
Biggi
It's the clock spring. It also houses the steering column electronics unit.
