Bleeding clutch
any tips for bleeding the clutch on a mk1 vrs. Ive swapped the slave cylinder but cant get any pressure back in the pedal
watch very carefuly this clip and bleed your slave cilinder by the same principle....you have to remove the cylinder from the gearbox but still with the line in it.
Is the best method you can bleed the clutch
Should my clutch pedal be returning at all? At minute mine just hits the floor & doesnt return
Sorted the clutch all bled and happy with it but no reverse gear.
Any ideas?
Tried Above idea and it popped the slave cylinder got a 2nd 1 now but not keen on doing the same again. Tried using an eezibleed but nothing happens from the slave cylinder. Just now have a rock solid brake pedal. Deffo got air in clutch system but cant get rid of it. Any ideas?
