Front Subframe Bushes
Hello there;
I have a Mk1 Octavia RS with some front end knocking of which I am going to overhaul the bushes on the front suspension. When looking around the front end I noticed that my front subframe bushes are very tired
CA794ACF-671B-430D-B5F8-C5C41092DC3C_zps
As you can see they are splitting and need replacing. Now on limited info and reading it appears the standard bush is a one piece which will need pressing in which will be an absolute ball ache of a job. However on reading it appears that the Audi TT two piece subframe bushes may fit
E245DCE8-0599-4719-9D5D-CD9214943458_zps
These are the part numbers I have found for these
Upper Mounting – 8N0199282C x2
Lower Mounting – 8N0199282D x2
Question is will these bushes fit and do I have the right part numbers? These bushes will make my job so much easier and could be done with the subframe in situ in theory. I can't seem to find any polybush equivalent so any other advice suggestions would be appreciated
Pete
Edited by northener51
That is not the standard part for Audi TTs of the same age as the octavia.
No idea if it fits but you'd be beest to do the job right
get new front and rear bushes and also do balljoints at the same time
Andy;
That thread you have posted answers the question perfectly thanks
