Starting issues
Hi guys looking for a bit of help, recently my 2005 VRS has developed a strange problem when trying to start, it starts and fires straight away but immediately conks out, you then have to keep it turning over pumping the throttle until it eventually comes to life. Running ok once started.
Have you got a diag checker? That might be able to give you the fault code
Wonder if your battery is getting nackered. Alternator faulty.
I got full car breaking and another on the way let me know what u need
i
It had a new battery in December and had the alternator pulley done in November last year.
Ok will do cheers Steveo
i
Check wites to starter motor are not worn.connections.
Does it run lumpy once started?
No mate runs fine
Starter working fine, turns over
If you look up crank sensor. Think it could be the reason.
Possibly abit of **** stuck infuel line perhaps.causing the sudden stop have you fuel filter replaced at all?
any lights glowing on the dash? could be a lazy fuel pump
No lights on dash mate
I think the crank sensor has been replaced last year as well, It would not start when in the garage and they did replace a sensor, it probably is due a service to be fair.
Seems to be getting worse, just seems to be when cold, starts ok when been already running. Do not seem to here the scoosh noise I used to here when you  first turn the ignition on any more either.
change the fuel filter
yes that be fine I got 1 though and fuel pump if needed
Cheers Stevo, I have just ordered the new filter and will order a new relay as well for all that it is, cheers anyway mate.
fuel filter could have collapsed restricting flow of fuel until its actually running we've had a few in work with similar problems
Right guys, I have changed the fuel filter and fitted a new fuel pump relay, problem remains, when trying to start she usually fires first time then conks out and you have to turn it over for ages constantly pumping the throttle until it eventually fires up. Any ideas?
pull the main fuel feed off filter and crank car see if its gushing through there ok if so next thing would be tandam pump
