Engine replace from 2015 to 2011
Hi i just about to change to new engine from 2015 skoda superb but i dont know its still a same engine and nothing been change or updated??
Anyone knows?
how much are you changing?
the lot, the top+bottom, injectors/pumps?
have you checked the engine codes? like for like is usually the safest, and use the old injectors and ECU till its up and running
Hi i want to change all engine, code looks same, put in completely new-one
wow, that cant have been cheap, if its all complete and comes with ECU you should be ok but the alarm and keys will/might need programming
