electric power supply
Hi , Help please as when it comes to car electrics I get totally lost and confused. I want to run a twin usb  , one to charge my mobile, usb port fitted in centre blank on dash , and the other usb to run my sat. nav .  I am fitting in the top storage on the dash so that it flips up( I hope) also fitting a windscreen camera. I would like to run these only when the ignition is on, My questions are where do I take the supply from, and can I run all from the same place and what amperage fuse do I use. componants already purchased.  Any  help would be appreciated.
There should be empty sockets in your fusebox, buy some fuse taps from eBay and use them in the sockets. Just use a multimeter or bulb to test if they are ignition or permanent lives.I had both so you may have the same.
Also make sure your usb components have a little box which steps the voltage down from 12v to 5v.
If you are feeling a little more adventurous drop the lower steering trim and access the back of the fuse box and insert a repair wire with terminal for the positive to keep it tidier. There is a grounding point at the top right of the dash fuse box for the negative.
A 5amp fuse should be sufficient.
Also make sure your usb ports have a little box which steps the voltage down from 12v to 5v.
Are your two usbs a double on the same circuit? If so a single fuse can cover both.
What the above posters have said. Use decent quality cable (I reccomend 8amp) though and ensure all your connections are good and sealed.
This might give you some pointers that help a little - LINK - .............Tony
Thanks . Got all the wires in and hidden yesterday, to Hot in the car in the sun  to do any more . all I have to do Know is find that power supply.
