1.4 mpi fuel filter - with / without pressure regulator ?
Hi guys,
What type of fuel filter does the 1.4 mpi engine (8V, ATZ) have ? I'm speaking about the one located under the rear wheel arch. I can see there are a couple of models, basically with and without pressure regulator. Is the pressure regulator a spare part that can be ordered along with the filter, or a feature that the car should or shouldn't have, according to some other specs? Which P/N should I order ? 6X0201511B, 6Q0201051B or 6Q0201051H ? My car's VIN is TMBNB46Y0Y3035992....if it helps.
Thank you !
  • Sponsor
Have a look at your present one. If it has only two pipe connections then the pressure regulator (and fuel return line) is at the fuel rail instead.
