Banging noise from the rear
there's a banging noise from the rear of my 1.4 x reg fabia.when i go faster then 20mph and go over holes in the roads there is a noise like is coming from under the car at the drivers side.
when the road is is in good con there is no noise.i've pushed down each corner of the car and suspension seems fine.
i've had a quick look under the car but not enough space to get further under.
it started after i went with the dog too the park this morning where their is speed bumps on the road outside but i don't drive fast over them.
when i bought it the garage said one of the rubbers on the exhaust was missing but they had fixed it,could it have gone missing again ?
thanks
Couple of teenagers on the back seat? :rofl:
try your spare tyre, that might not be fixed tightly enough my fabia used to do that its W reg, but never had a problem with the exhaust
Take it in to D M Keiths. I suspect you bought it from them and it still has some warranty? They are v good
no i bought it from Fletcher bros near Halifax.the warrenty ran out 6 weeks ago. i'll try the spare tyre tomorrow.
which way should the arrow be pointing on the black box inside the spare wheel ?
thanks
thanks
err i havent got it in any particlurar way on but theres a screw on platic bolt that goes inside the tool box throught to the spare wheel (center) and then onto the floor once thats tightend, it should be fine and secure also maybe bits arn't put in place properly it should be fine afterwards i remember it used to happen all the time when i drove over speedhumps
hope that helps
i have the same problem - getting bored of taking it back to the dealer now! taken it 3 times now - and the problem is still there!
it really is frikking annoying too! The dealers have checked everything, and even replaced the back seat clips....
i will ring tomorrow to book it in again! but ill have to wait yet another month to get a c / car, and if it doesnt get fixed, it will have to be another month again etc!
i checked my spare wheel, and that was loose, but that was not the problem. I personally belive its the exhaust on the car. But its not every bump for some reason.
The roads next to the dealer have a smooth surface, so im not even sure if they can hear the noise.
removed the spare tyre,tool box and everything out of the boot and went for a ride but the noise is still there.
i'm of to a garage on friday to have the exhaust looked at.
removed the spare tyre' date='tool box and everything out of the boot and went for a ride but the noise is still there.
i'm of to a garage on friday to have the exhaust looked at.[/quote']
jim, keep me informed please.....
out of interest - what dealer u go to?
jim' date=' keep me informed please.....
out of interest - what dealer u go to?[/quote']
i bought it from a former skoda dealer Fletcher Bros near Halifax.they very helpful but i'll be going to my local garage to have a look at it.
Look at your rear bump stops ; they may have perished and dropped onto the shocker; when you hit a bump they bang around; sounds very loud and worse than it is.
Cheap and easy to replace.
Does it do it with the rear seats folded down?
just been to my local tyre and exhaust centre and the guy starting pulling the exhaust at the front then at the rear and found the exhaust mounting is broke.
have to go back tomorrow when he gets the part in.cost will be around
havent tried - but they have replaced the clips to the seats
sholdnt cost you a thing! now that you know exhaust mount is broke - why dont you take it back to the dealer to get it done for free?
the warrenty ran out a month ago.sadly !
went to the exhaust centre this aft but it wasn't a mounting that was broke.they had it up the ramp,went for a test drive but said didn't know what it was.they told me to goto the dealer (fat chance)
so went to my one man garage,he was closing up but we went for a test drive,he said the noise was coming from the front left.
it went on the ramp and within 10 mins said it was the ANTI-ROLL BAR BUSH on the chassis.
so have to find a cheap bush somewhere.
hope this helps others !
james
went to the exhaust centre this aft but it wasn't a mounting that was broke.they had it up the ramp' date='went for a test drive but said didn't know what it was.they told me to goto the dealer (fat chance)
james[/quote']
when u have found one and got it fixed would you let me know james please
James
Several numbers for the ARB bushes depending on ARB size. Only about
James
I wasn't too far out then eh. :P
Get both done, it may affect the handling otherwise.
This happened with my previous car.
Extremely irritating sound.
got both bushes done and both were very worn.drives like a new car and so quiet again. local garage did it for
u have pm james
