Just a few problems help please
Right walked out of work to see my lamba sensor had been cut (could see the wires hanging down) drove it home all was fine, drove it Saturday started juddering thought great what's wrong now, Sunday going to pick my daughter up I lost all power the epc light came on and the traction control light and car wouldn't start when it did it wasn't idling right at all so shut it off got the car towed home and scanned the car I have these come up
16514
17524
16396
17840
16885
16955
16726
17953
17705
17972
18010
17967
1. lamba sensor number 2
2. lamba sensor number 1
3. Cam shaft adjuster
4. Sai resistor
5. Vehicle speed sensor
6. Brake light switch
7. Camshaft position sensor
8. Throttle valve controller
9. Pressure drop between turbo and throttle
10. Throttle actuator
11. Power supply too low
12. Throttle body fault
Could the lamba have caused all of these to go ?
 Some of those codes could be historical so clear the codes & see which ones comes back.
Also, some of them could be false positives where they will clear when the lambda wiring is fixed.
Fixed the lamba wire cleared all the codes went to reset the throttle body and boom throttle body is dead :(
I'm certain I've just seen a couple on e bay.
Looks like I've got one, pm me if interested.
Already have one on the way boys should be here Monday so hopefully it's fixed then and back on to sorting the exhaust out
Right changed the throttle body and I'm still getting 3 codes up all to do with the throttle body what else can it be ?
Wiring fault to the TB or EPC (Accelerator pedal).
Pull the battery tray out and check the wiring under there seen a few with wiring rubbed through under there
