tapping sound
Hi, i seem to have a strange tapping sound coming from the engine it starts at motorway speed and seems to tap worse as i accelerate anyone had this before / know what it could be?
Check the oil before anything els.
What engine do you have?
Looks a poor guide.... Wouldn't trust that :D
its an ASZ engine, the oil is fine i checked it a couple of days ago and it was just under max the car is on 94k and its a 2004
and even with that guide i wouldnt wanna try it myself im not very mechanically minded lol
The squirrel is starting to get frightened and wants you to slow down? ;)
lol must be that tbh
Are you sure its the engine? Have you tried the same speed in a different gear. I would have thought the engine would tap all the time. Could be a rotational issue.
You anywhere near Croydon, I can scan it for any fault codes.
Possibly a hydronic tappet gone down.
Could be a gearbox bearing worn out, when my 3rd(!) gearbox went it rattled like crazy when under acceleration
its defo engine its usually when im in 5th from around 60 mph on wards when i accelerate the tapping gets faster, when i stay at a consistent speed it stops to some degree. if its a tappet is this an expensive repair?
and im in Sheffield so pretty far from croydon mate thanks though.
depends if you can do yourself
http://www.ebay.co.uk/itm/HYDRAULIC-CAM-FOLLOWERS-TAPPETS-SET-OF-8-NEW-FOR-VAG-1-4-1-9-2-0TDI-ENGINES-/391160128288?pt=LH_DefaultDomain_3&fits=Model%3AFabia%7CCars+Type%3A1.9+TDI+RS&hash=item5b12f5e320
i wouldnt trust myself to try tbh lol but if i buy the part i can get them fitted
yes garage would prob charge you 2 hrs labour
Thanks for the help :)
