Brake Servo Hoses - Advice required!
Hello All,
Second post for some further advice, separate parts this time! Do any of you know where I can purchase the following? I've had a nose around the forums but I couldn't really find anything other than pictures of one of the parts:
1J2612041K
1J0612041ES
Ebay search returned a couple of results for 1J2612041K, but not with that specific part number... however i cannot track down the part for 1J0612041ES. Can you use Silicone Hoses out of curiosity instead for these two parts? If so what size?
Thanking you in advance,
Joe
For 1J0612041ES I'd try your local TPS or if they won't sell to you (they only technically do trade sales but most branches will sell if you walk in with a part no) then you can order from a local Skoda garage.
I had to replace mine earlier this year as well as the pipe split at the non return valve and basically lost brakes approaching a roundabout at 50! Think it was about £30 iirc.
Alternatively yes you can use vacuum pipe, many have done this - just make sure you retain the non return valves from the old pipe work. I don't have experience of it off hand though...
Cheers Girardi. I'll have a look around and see what I can find. Would like to go the silicone hose route as it will be much cheaper.
