front suspension knock
hi ive got a knock on n/s/f suspension and im at the end of my tether im posting to see if anyone has any answers/ideas what it could be.here goes..
ive changed n/s/r wishbone,track rod end,fitted poly anti roll bar bushes and poly top mounts had tracking done all in the last month (less than 500 miles since) all because i have a knock when i go over bumps or on full lock to the left, not when im driving straight mind and also when i reverse out of my drive way after car has been stationary for a while.all mentioned parts that have been changed have been fitted correctly and torqued to haynes manual info.its doing my head in now as ive spent a few quid on parts,the cv boots are not split.could this problem be the drop links as ive changed most parts except the drop links,would they cause the load clunk ive mentioned? im going to start doing alot of mileage due to work commitments and ive got no confidence in the car at the moment.could i have a knackered spring? can anyone help??
cheers
I would do the drop links then ball joints then look at cv joint if the first 2 don't sort it
drop links defo!!
They make a very distinctive knock and can be very random on when they knock...
