Vrs and Monte Carlo springs
well as I understand it are they A) the same and B)slightly lower than the other model Fabia springs can anyone confirm this?
Diesel Monte Hatch springs might be the same as Fabia vRS Mk2 ones.
Check if Petrol Monte Hatch are the same by checking with a supplier, or someone maybe has the numbers.
Estate Springs at the rear are different from Rear Springs for a Hatch.
When my dad got his Monte we compared our ride heights and the Monte and standard Fabia are the same height.
But then the official Scores on the doors has the roof height above the ground as,
Standard      1,499 mm   Under Clearance 134mm
Greenline II  1,484               "           "          119 mm
vRS              1,492                                      129 mm
Monte           1,493                                      129 mm
Then you can get 'Sport Suspension' on Standard cars.
& vRS & Monte on OEM Springs is lower than a Standard Fabia on Standard springs when new.
4, 5, or even 6 mm difference in roof hight can be hard to notice.
then cars can be a few mm higher on different tyres.
Edited by goneoffSKi
vRS              1,492                                      129 mm
Monte           1,493                                      129 mm
Or even worn tyres if we're talking mm.
Well in that case i have some vrs hatch springs for sale :)
Sent from my SM-N910F using Tapatalk
