Cooling fans problem
Hi
Recently had my radiator replaced since then my cooling fans come on full as soon as I turn the ignition. I've connect computer and it came up with outside ambient temperature sensor. I've replaced that but still not resolved the problem. Please help
Hi
Hi. Did you have the rad replaced at a main dealer? If so, go back and tell them to check it...
No it was done by independent garage. It was fine for week then the fans just came on
Might be worth a trip to a dealer to get them to check....
have you cleared the original fault code as the car will still think its faulty even though you have changed the part also check for correct coolant (red stuff) & try bleeding it.
soon as u clear the fault code it comes back on. The fans seem to have gone off today but I'm sure there's something not right. Can anyone recommend a garage to get it fixed from? Around the Manchester area.
