Water leak or condensation?
Hi guys,
I noticed a damp patch under my mk 1 Octavia the other day. On investigation I found water droplets coming from what seems to be a rubber 'vent' behind a flap in the sound-deadening pad low down on the baulkhead in the engine compartment on the passenger side.
The 'leak' stops after a while but re-appears when the engine is started. No water loss from the radiator expansion bottle.
Where is this water coming from and do I have a problem?
Thanks,
Mike
Air-con humidifier?  If so, perfectly normal?
  • Sponsor
Yep, air con evaporator drain. Normal.
3rded.
I can always rely on you guys, thanks. So I don't have a problem at all,
Regards, Mike
