converting to KO4 power what is needed?
Ok so I'm aiming to upgrade the power of the car to KO4 turbo power and fuelling etc.
The list below is my start for what I think I will need. If anyone can help by adding to it I'd be very grateful.
1. KO4 turbo
2. Fuel rail
3. 4 bar 'in tank' fuel pump
4. Injectors
5. 4 bar fuel pressure regulator
Also nice to have would be uprated clutch and a front mounted intercooler along with obviously a remap.
My car is a 2003 Vrs btw
You'll also need:
Manifold
Coolant and oil feed and returns, these are different to K03S.
Support bracket for turbo
Downpipe and some sort of cat/by pass and reducer connector for exhaust if using standard system
Turbo inlet pipe, original rubber or aftermarket silicone version
3" Maf housing + air box or aftermarket filter
Upgraded intercooler and revised tubing routing
Remap
That should do it
If you can get a KO4-001 its a straight fit to your existing manifold and oil lines etc..
But dont run as much power afaik
Edited by BrownBarge
Cheers guys. Got a shopping list. Now to keep an eye out on fleabay :-)
