Steering Wheel Options
Hi,
Does anybody know if it's possible to put a steering wheel from a Mk3 Octavia vRS onto a Mk1 Fabia vRS??
I know the controls for the stereo, etc wouldn't work but wondered if there might be some other reason it might not work.
Also, failing that, would a Mk2 Fabia vRS steering wheel work instead??
Thanks,
Cheers Charlie. Do you happen to know the going rate for an airbag??
Never had to look into it.
That one I linked comes with the airbag :)
Pretty sure the airbag connection on the slip ring wont be the same.
Ah, bugger. :(
How about the Fabia Mk2 steering wheel??
Citago sport steering wheel looks nice and has a flat bottom.
Not sure if it's a straight fit though.
The MK2 Fabia will use the later airbag wiring too (different plug) so you need the wiring loom that goes in between the airbag and slip ring.
  • 7 years later...
Is it possible to install either the mk2 fabia or mk3 octavia vrs wheel with the correct wiring loom ?
