ultra racing rear anti roll bars fitted :)
You managed to suss it out without the instructions then :thumbup:
How different does it feel?
Is that 2 separate bars on the rear??
yes 2 different bars feels more like a 205 gti now you can throw the back out and just tweek the wheel for it to come back in line well worthy mod going to get the middle brace and front brace in coming weeks
They do a rear anti roll bar, and a rear lower brace, as well as the others too.
Pictured is one that sits infront of the rear beam and one behind. Adding even more rigidity.... In theory.
I've been considering a Whiteline FARB but not sure if it's worth it, i've got the RARB and been running it on the stiffest setting for over a year now, handles great
theres 6 in total available for the fabia mk1 this is the only rear anti roll bar that does not need bushes (that im aware of) so will never wear or snap brackets
That's the reason I fitted the ultra racing one a few weeks ago.
Any drilling required for the brace? I know the roll bar fits straight on. Looks cool as hell
no drilling required for any of their braces all nuts bolts and washers supplied aswsell
Look good :)
Still don't understand why manufacturers call them anti rollbars though!
They are a beam brace/stiffener, as a anti rollbar is connected to the cars body to reduce roll.
With the Ultra racing RARB how does the water drain out from the bottom of the spring cups, do they supply a new drain system?
I'm assuming the ultra racing RARB bolts up to the four existing drain holes, so blocking them off?
Yeah they block off the drain holes, doesn't bother me in the slightest, the rear axel isn't going to drop off.
you got a link to these on their website as I can't find them for the Skoda or are you ordering them for Vw polos??
I should add, I have coilovers so the adjusting cup sits in place so raise the spring away from the axel also.
Would take nothing to drill an extra hole if it botherd people.
found them must have been on wrong site..
Edited by smithysmoo
What's the website
crest motorsport
