Single Din to Double Din - Quick Question...
Hi
I am after some quick advice...
I have a 2004 MK1 Octavia with original factory fit stereo (single din) which has the little single din storage space under the stereo...
I am wanting a double din stereo in and so my question is this - do i need a double din cage or is there one in that holds the current stereo and storage area ???
Thanks in anticipation....
Stu
It needs the double din cage (should come with a new one), when you remove the single din and box all that's left is the plastic area for it to fit into, I had to remove the 'H' bit at the back to fit mine in properly.
