MAP sensor screws
The MAF is duff so I need a new one but can't unscrew it as the screws are unusual.
Using VCDS lite>>engine>>code 3>> at 3500RPM the actual air flow is 800 odd whereas the MAP measures 500 odd.
Seem to be a polydrive from wikipedia
https://en.wikipedia.org/wiki/List_of_screw_drives#
What kind of socket is used to unscrew them?
Edited by jackg
dremel then replace
they are secured torx,is like a torx with a whole in the middle
Yep anti tamper torx.
you can get a set in most any hardware shop, used in many bits and pieces so worth getting :)
Thanks all.
The whole thing is replaced, these screws typically, are not removed.
Screwing around on ebay for the whole assembly.
Got them both off after a fashion.
