Octavia Car Service (Newbie Qn)
Now this might be a really simple qn;
but I have a V reg Octavia, with 48k on the clock.
It's due a service (keeps on flashing me the message when I stick the keys in the ignition) and a good car friend of mine has said that I need:
1) Annual inspection
2) On top of that also look at getting oil changed and brake fluid change, looking at the coolant, possibly replacing the Alternator/Drive belt
3) Possibly go for the 20k inspection
I'm ringing round this week, but I just want to make sure that I'm not going to be ripped off/over charged.
Can any clever car people tell me how much 1, 2 and 3 will be? I assume that the 20k inspection is more than the annual inspection and includes all the bits that you get for the standard inspection?
When was it last serviced , and do you know if it's on fixed or variable service intervals?
The annual service includes the oil change and will probably cost you about 250 quid.
You might be advised to get the cam belt changed , but that depends on if it;s been done before and what model of octavia it is
it was last serviced a year ago - how would I know if it's fixed or variable service?
250 quid? How much would the 20k service cost?
Roughly how much would a cam belt cost?
Can I go to anyone other than the Skoda dealer? Or is it recommended that I go to an official source?
My 10,000, 20,000 and 50,000 mile services cost me the princely sum of
If it's a V reg it'll almost certainly be on fixed servicing. 10 k intervals. You don't say what engine it is, but mostly they require the cam belt changed at either 60k or 80k. As Greg says, the even numbered services are more expensive than the odd, which are pretty much just oil changes. Your engine probably uses much cheaper oil than the fancy longlife stuff, so the service should be correspondingly cheaper.
