Coding Errors - Help!
I've undertaken a few mods on the Superb - XDS, HHC, Comfort Turn Signal, hidden menu on the Columbus. I scanned the car before hand and after and had no errors.
I wanted to add Easy Entry this morning and did a full scan as advised.
Now VCDS has thrown-up two error codes, the first in address 19, CAN Gateway (J533) and the second in 4C, Tire Pressure II, which was not there before, but perhaps its something to do with the enabling of XDS?
Here's the full printout - hopefully someone can show me the error of my ways!?
Thanks in advance!
Saturday,18,July,2015,11:22:36:34064
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN:                       License Plate: YD61JOJ
Mileage: 46530km-28912mi   Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 36 37 42 44 46 4C 52 55 56 62
          72 77
VIN: TMBBF73T9B9066857   Mileage: 46530km-28912miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 CH    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H23 7825
   Revision: 42H23---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_ECM20TDI01103L906018CH 003005
   ROD: EV_ECM20TDI01103L906018C.rod
   VCID: 72EBC064A52A31B168B-8027
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 863D601609280000611306E990200082350C00
   Shop #: WSC 33361 790 00063
   VCID: 76E3FC74C1422D91443-8023
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK12.rod
   VCID: 76E3FC74C9422D91443-8023
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 P    HW: 1K0 937 087 P
   Component: BCM PQ35  H+  104 0615
   Revision: 00104 AF
   Coding: 48990AB8E85BF1C040080080310089E4477000AE732085605C8040000040
   VCID: 3E732454A9F2A5D15C3-806B
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 11041  26  0602
   Coding: 00DFB7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 290411 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 3T0 919 475 C    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0005
   Revision: --------    Serial number: 13991109050258
   Coding: 109004
   VCID: 3D712358A4F4BEC9459-8068
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LAU VW10 HI   1918
   Revision: 20014000    Serial number: 003K2P83181S
   Coding: 0016725
   VCID: 41895FA8180CDA29211-8014
   Subsystem 1 - Serial number: 6332MTS604491011
   Subsystem 2 - Serial number: 6342MTS604591011
   Subsystem 3 - Serial number: 6351HTS61R1QU9KJ
   Subsystem 4 - Serial number: 6361HTS65P6PU9KR
   Subsystem 5 - Serial number: 63727TS6U55DU9KJ
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110429100588
   Coding: 008A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 941 H    HW: 3T2 920 941 H
   Component: KOMBI         H20 0420
   Coding: 410F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
   VCID: 3A7B2844BDDA89F160B-806F
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 010511F1000268
   Coding: 353303
   VCID: 306F0A6C63A643A1DEF-8065
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 19
                    Reset counter: 255
                    Mileage: 46468 km
                    Time Indication: 0
                    Date: 2015.07.08
                    Time: 17:39:54
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6ADBD8048DFAF971D0B-803F
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   VCID: 72EBC0646D2A31B168B-8027
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 A    HW: 3T0 035 680 A
   Component: RNS-MID       H52 2844
   Revision: AB001001    Serial number: SKZ6Z7L9114081
   Coding: 040004020004008100
   VCID: 2E53141479925551CC3-807B
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE01001000
   VCID: 4FAD69901E583C59A75-801A
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 195    3201
   Revision: 00H20000
   VCID: 3467067C57BE7F81BA7-8061
Address 4C: Tire Pressure II
Cannot be reached
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4E93749419523551AC3-801B
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1377095
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000021
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200001001000
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H06 0409
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
   Component: Telefon       009 0511
   Revision: --------    Serial number: 35909603150648
   Coding: 020100000100010000000000
   ASAM Dataset: EV_UHVPremi A01005
   ROD: EV_UHVPremi_SE36.rod
   VCID: 2959E708487C3269191-807C
End-------------------------(Elapsed Time: 03:38)--------------------------
save the gateway coding then remove it from the installation list, do a can bus reset then recheck it.
If 19 is throwing up that code and it can't reach that component then it's not installed.
Many, many thanks for the suggestion.
Please can you tell me how I save the gateway coding, remove it from the installation list and do a reset?
Also, what concerns me little is what have I done to enable this too. It wasn't in the original scan of the car I did before attempting any mods?
Thanks once again for the suggestion Rev...
Go on to 19 gateway and open up long coding helper and save the code. then go out of coding helper and on to installation list and un tick tyre monitor II and apply the coding.
Once applied erase any faults (the fault may have changed to intermittent by this point) and exit gateway and vcds.
remove the keys and lock the car. leave it for a minute or 2 until the alarm is active. By this point the can bus network will have entered sleep mode. unlock the car and do a rescan to see if the issue have gone.
Thanks Rev. I'll try a dry-run in the next couple of days to ensure I'm able to follow your instructions.
Thanks agin... Rob
