Climate control
Hi all, may seem like a strange question but what is the lowest temp that you can set the climatronic display to? Currently mine reads 18 degrees then one more click down goes to LO, I am pretty sure it used to go down to 16 degrees but cant swear on it. car is Fabia VRS 61 plate.
Mine is 18deg lowest I think.
Yep same here.
18 also.... must have been another car....
I think when it's on LO it's 16 degrees as on my partners MK7 golf LO is 16 then goes up in .5's
It must be the other halves Quashqai that goes down that low. Oh well ill stick to keeping the windows open. Cheers guys
Air con not cool enough for you?
I set mine to come out of the vents in the dash and its always been cold. Even when its 30 odd degrees outside
