Engine sound and Stop/Start
Now I expect it is just me, but why does my engine sound different now the car has done 7500 miles?
When I say sound different, what I mean is when driving at 55-60MPH the engine seems to sound slightly noisier than it did a while ago.. not real noisy, but sounds slightly louder as if it needs to change up gear, even though the revs are normal, around 1700-1800 rpm....
It has not just started it has been like it a while :(
Also, I think I know the answer to this, whilst sitting at the traffic lights STOP/START activated after a minute or so the engine started on its own, what would cause that? I am certain I did not lift my foot off the brake... so could it be the AC was needed to cool the car a bit inside? or maybe the battery needed a boost?
Stu
Hullo,
On point one, i couldn't say I've never been fortunate enough to have such a young motor. But I'd imagine it's just bedding in.
On point 2 having driven fords/vauxhalls with stop/start this isn't unusual behaviour and I think it's to prevent battery drain
Lol... hate modern cars, those were the day's when I could take my old Ford Cortina to bits ... nothing fancy...
That was what I thought (ref point 1) my old Exeo did seem to change sound... I did suspect it may be down to either the AC needing to work or the battery needed a boost... It does say in the manual that it can do this, but when it happens for the first time it takes you by surprise Lol
Stu
Battery is powerful enough. It`s the AC.
I have a feeling it could be the AC, although it is 18 degrees here and the AC is set to 18 then the inside would be slightly higher and it did go a little warmer inside just before it restarted...
No.
When starstop system restarts on his own, the capacitor needs energy. The ac is anyway in a special mode when you stops.
This is absolutely normal behaviour.
From tapatalk
In 12 months it's the first time it has done this .. Lol just surprised me :)
So it was just the battery needing a boost...
Mine 1.4 tsi has stop start and manual air con and I can confirm that the air con doesn't affect the stop start. When I was in Germany earlier this month with temps of 39 deg C when the stop start kicked in  (or off!!) the air con stopped cooling. I restarted by putting my clutch down to avoid cooking!
When I was sat in the ferry queue I also experienced the engine restarting itself after a while - presumably because of the DRL's being on .
The stop / start system is quite a complicated process with a varying number of influences...
Conditions for the automatic engine shut down (stop phase)
› The gearshift lever is in Neutral.
› The clutch pedal is not depressed.
› The driver has fastened the seat belt.
› The driver's door is closed.
› The bonnet is closed.
› The vehicle is at a standstill.
› The engine is at operating temperature.
› The charge state of the vehicle battery is sufficient.
› The stationary vehicle is not on a steep slope or a steep downhill section.
› The engine speed is less than 1200 1/min.
› The temperature of the vehicle battery is not too low or too high.
› There is sufficient pressure in the braking system.
› The difference between the outdoor- and the set temperature in the interior is
not too great.
› The vehicle speed since the last time the engine was switched off was greater
than 3 km/h.
› The front wheels are not turned excessively (the steering angle is less than 3/4
of a steering wheel revolution).
Conditions for an automatic restart (start phase)
› The clutch is depressed.
› The max./min. temperature is set.
› The Defrost function for the windshield is switched on.
› A high blower stage has been selected.
› The START STOP button is pressed.
Conditions for an automatic restart without driver intervention
› The vehicle moves at a speed of more than 3 km/h.
too great.
› The charge state of the vehicle battery is not sufficient.
› There is insufficient pressure in the braking system.
Stuart, I have the same issues. Engine sounds louder but not bothered much by it, I assumed it was starting to loosen up. The engine does restart, I have noticed this when it is on a short journey, the power need to start the car from cold is, so I have been led to believe is quite high, plus lights on, heater on etc, the alternator kicks I power it all.
not too great.
than 3 km/h.
too great.
Great answer thanks,
My engine probably didn't re start when stood at lights on a very hot day as you don't set an interior temperature on manual air con
"› The difference between the outdoor- and the set temperature in the interior is too great."
When the car restarted after being sat in a very long ferry queue it was probably "the charge state of the vehicle battery is not sufficient" - The car had numerous restarts and had sat with the DRL on for some time (not LED)
not too great.
than 3 km/h.
too great.
It does sort of contradict itself really ...
Now mine stopped OK then about 30 seconds later restarted... Which is why I suspected the internal temp was too warm so the AC was needed ..
I would not say it bothers me, if I remember right my Exeo did the same thing, it is just slightly noisier now around the 1500-2000 RPM range just as if it want another gear..
