diagnostics &vcds
Hi this is to anyone I drive a skoda octavia 2lt L&k 06 plate i've had numerous cars honda toyota ford nissan ? I like the skoda got all that i need in comfort toys to  make life nice to go for a drive,TILL you pull up at a hotel just get comfy and the bloody alarm goes off,Not good at 2 in the morning and most of the guest have pacemakers. could i stop no the only way was to leave the car unlocked .no matter took the car to local garage he plug his vag com in no faults it did bring sum up parking light but its working and a few others up that are also working .The point to all this is ive still got an alarm that goes off when it feels like it the rear wiper does half a wipe then parks were it wants ? NOW i bought one of the genuine Ross-Tech from gendan  ,plug in did a full scan found a few more faults but not one for the alarm and its still going off can you dig deeper with this toy or dose it just tell you there is a fault .witch in this case the alarm is telling me so is the wiper ?regards oldtimer66 yes thats my age and ive worked on cars for many years  :coffee:
Welcome
Post up a copy of the full scan and we can go from there.
Hi gizmo68 thank you for reading my topic , I will try to upload the information you ask for later to day .The point of the topic to be fair is I've looked at numures topics on the rear wiper and alarm sarger and most keep saying get a diagnostic test ? Then comes the cost ? Then should I bye my own me thinks that could save some money ,then witch one top of the range Bluetooth ,wifi,cable,The point is they all cost and if like me you think plug in problem solved ? Your wrong ,that's when it all goes tits up .(give me old car and a few spanners they were the days ) We should have a meeting say a training day for dummies on how to use vcds and we can all save money and help one and all regards oldtimer66 ps hope I don't bore you
A scan with VCDS will show the exact reason for the alarm going off. it could be anything from a dodgy sensor, door switch, or the battery in the alarm sounder itself.
Log-FE06DZL-TMBGE21Z162212069-145690km-90527mi.txtwell sir just to let you no this is what i'm on about you see the car has had a scan with my brand new ross-tech vcds up to date software .before that the garage that dose all the services on the family's cars AND to top it all skoda main agents in chesterfield today and could not find the problem or help so i've ask the garage to disconnect the dam thing? bye the way all of the scans put up no fault codes strange yet it went of there i'm going to post my scan if possible then when i get the print out from skoda i will post that as well regards oldtimer66
Tuesday,21,July,2015,18:26:59:30882
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: TMBGE21Z162212069   License Plate: FE06DZL
Mileage: 145690km-90527mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 36 42 44 46 52 56 62 72 76
VIN: TMBGE21Z162212069   Mileage: 145690km-90527miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 DS    HW: 028 101 195 3
   Component: R4 2,0L EDC G000AG  7000
   Revision: 12345678    Serial number: SKZ7Z0E3381836
   Coding: 0000078
   Shop #: WSC 73430 790 00000
   VCID: 77FDA74806B5E6995F5-8022
4 Faults Found:
18104 - Powertrain Data Bus
            P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.70 V
                    Bin. Bits: 00101100
                    Bin. Bits: 11000000
                    (no units): 4.0
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 819 /min
                    Torque: 42.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.44 V
                    Bin. Bits: 00101111
                    Temperature: 16.2∞C
                    Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 819 /min
                    Torque: 42.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.44 V
                    Bin. Bits: 00101111
                    Temperature: 16.2∞C
                    Bin. Bits: 10110000
17978 - Engine Start Blocked by Immobilizer
            P1570 - 000 -  - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.69 V
                    Bin. Bits: 00001010
                    Bin. Bits: 11000000
                    (no units): 1.0
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 042 S    HW: 02E 927 770 AD
   Component: GSG DSG         082 1117
   Revision: 05508020    Serial number: 00001107060467
   Coding: 0000020
   Shop #: WSC 04940 001 00001
   VCID: 2345A318E2AD5A3953D-8076
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8D0F686E051ED9575-806A
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 J
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3D71756064090CC9459-8068
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003799049
   Coding: E18A8F030004140000110D000000000000087F075C
   Shop #: WSC 28008 576 05695
   VCID: 2B554B388A7D9279EBD-807E
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 28008
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 28008
2 Faults Found:
02395 - Parking Light Front Right (M3)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 86
                    Mileage: 145590 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 90
                    Mileage: 145593 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.15 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: Q4 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD05BEG6
   Coding: 0020788
   VCID: 3B757B787A1D02F97BD-806E
   Subsystem 1 - Serial number: 6332MSME0D4E1833H
   Subsystem 2 - Serial number: 6342MSME0E44470EJ
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0012042
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           007 0050
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612038    Serial number: SKZ7Z0E3381836
   Coding: 0007401
   Shop #: WSC 28001 210 92281
   VCID: 39796170702130E9691-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105C261468
   Coding: 3F7F0740072303
   VCID: 2A5B4E3C85878B7110B-807F
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 B    HW: 3C0 959 760 B
   Component: Sitzverstellung     0701
   Revision: 00003000    Serial number: 00000000000000
   VCID: 2C5748248F739541E27-8079
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1T0 959 701 C
   Component: Tuer-SG         024 2438
   Coding: 0001014
   VCID: 377D6748463526999F5-8062
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 346750445743CD81BA7-8061
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01D002007F2D850548DF861004CC
   VCID: 79F9A17030A1F0E9291-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1T0 959 702 C
   Coding: 0001014
   VCID: 387F64744B2B29E196F-806D
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2435
   Coding: 0000144
   VCID: 326B565CAD57C3B1A8B-8067
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
   VCID: 33655358524DCAB9A3D-8066
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0001001
5 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 145197 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:56:44
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 145197 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:56:44
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 145197 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:56:44
01543 - Parking Aid Warning Chime (H15)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 145194 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:46:15
02070 - Rear Parking Aid Sensors
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 145194 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:50:32
End-------------------------(Elapsed Time: 02:12)--------------------------
Edited by Gizmo68
Scan attached
you have quite a few faults listed, I woukd clear them first and see which ones then come back
John
If you go on measured values on the ccm there's a data field which shows the last 4 alarm trigger reasons.
There's also an option in the ccm to fully deactivate the alarm system on cars of that year.
After you have cleared the faults a good place to start is the Ross-Tech wiki then you can see what each DTC means.
sorry for the delay in the out come of this topic but work takes priority and the truth of the matter is this ross teck is about as usefull as a chocolate fire guard in my hands :envy: to all that can use it regards oldtimer66
What are you struggling with and how computer literate are you?
It’s not hard to use IMO but then I have a fair understanding on how the software and mechanics / electrics work on a car, I appreciate not everyone is the same, but maybe all you need is a crash course?
Hi gizmo68 you are right not everyone is the same, a lot of the time i'm trying to understand the abbreviations , I think it's an other toy to my collection to gather dust regards oldtimer66
The acronyms and abbreviations are not Ross-Tech's doing - they are VAG's nomenclature.  In order to work on these cars today, much learning is required outside the scope of the tool one is using.
If Ross-Tech spent all the time needed to include the training required to build expertise, the cost of our product would be prohibitive to the DIY market. Yet, we have produced and published videos on our web site to assist with training.  There are others tools out there in the world wide web.  There are forums like this one to assist.
Oldtimer66, I too am an old timer who has had to learn all the new nomenclature having come to Ross-Tech with little knowledge of these systems.  I read and read and read... my goal is to learn.  If you would post your questions here, I am certain that the forum members would be pleased to assist.
