Door lock/alarm flashing door LED
Was just wondering if anyone could offer any advice on a small problem I've discovered.
The car concerned is a 59reg Fabia 1, so basic model. When we lock the car with the keys (no remote controlled central locking on this model) all the doors and boot lock, and the indicators flash. The problem is with the red LED light on the drivers door, this doesn't flash at all, although it previously has done.
Could it be a break in the wiring loom, between the door and the car, as I've read that is a common problem and have already had the passenger side replaced under warranty as the electric window wouldn't operate, or can anything else be suggested??
  • 4 weeks later...
Anyone?
If it did work but now doesn't then it sounds like a wiring issue or the LED no longer works, best way to find out is to get the door card off and take a look.
Replacements should be easily sourced at a scrap yard
