headlight adjuster / power outlet
Howdy all
two questions the headlight adjusters packed in I've dismantled it and a small chip has burnt out .is there a cheep fix or is it a scrappy job .then there's the power outlet in the boot .its dead is there any common probs is there a fuse ?
Thanks for your time looking
Jim
If the chip has burnt, then it's either a good used scrappy unit or a new one, unless you know someone into electronics who could source and solder in a new chip - not an option for most of us.
If you have a power plug in the boot, then I take it you have an estate?, if so, yes they are fused and it should be in the dash fusebox rather than battery one.
Yeah i thought as much probably be a full light unit aswell . Yes sorry it is an estate. Any idea witch no fuse it is as u don't have a hand book . Thanks again
Jim
