Fault codes
Back again folks with more faults. Got the same error code ass smithy18. 16395-bank 1camshaft-retard set point not reached P0011
17544-fuel trim bank 1 system to lean P1136
16727-camshaft position sensor=>sensor-G40 signal to high P0343
Please tell me it's a simple fix. Hope you folks can help again. Cheers fraser
Check your oil pick up feed as suggested by Phil in my thread. It's a cheap fix £8 for the pickup feed and £5 for the o ring from skoda. It's a messy job tho mate.
Pick up pipe in the sump? It's been done about 5000 miles ish ago but I believe it was cleaned and de scaled. Will recheck that. Is there anything else that it could be? Cat,battery goin down, dodgy sensor, maf breakin down? Cars not quite pulling as hard as it should can feel it on full chat. Goes then eases of on of on. It's buggin me. Just hope it's an easy fix
Bloody lights on again . But I did notice it wouldn't fire up first, then fired up on second turn of key. Could it be an issue which came from pick up pipe being blocked and maybe strained pump bearings, idler wheels, stretch chain? It's gotta be fixed, it's a decent car. Will have to get the fault codes again
