16555 - Fuel Trim; Bank 1: System Too Lean
Hey guys,
I keep getting this error code on my MK1 Octavia VRS 1.8.
Usually happens shortly after filling up. At first I put it down to how I was driving the car as I wasn't giving it quite enough power to pull away after getting used to driving a different car.
Seems to have started making an unusual blow off sound when I put the clutch in coming from the passengers side of the car.
Any ideas what it could be?
Tom
Vacuum/ boost pipes splitting is extremely common on VAG 1.8T's. http://wiki.ross-tech.com/wiki/index.php/16555/P0171/000369
I figured as much as I can hear air coming from the left side when I change gear, which I can't normally hear. Have taken a look but can't see anything obvious on the surface. I know a guy with a smoke kit so may have to get it tested.
