Cruise Control Problem
I swapped the steering wheel angle sensor module for a different one (same part no's etc) the old one had problems, new one is 100% except the cruise control now doesn't operate.
Can I get the car coded to recognise the Cruise Control or am I without CC now!?
If you've swapped out the unit with one with the same part number, I would hazard a guess and say "yes" get it recoded and it should work.
Only with VCDS and checking the coding you can really tell.
Do you mean the steering column control unit, or the angle sensor? Two different components, one will make a difference, one won't.
Sorry Tech1e it's the steering control module, changed it as I had a high beam problem that it was causing
Sent from my C6603 using Tapatalk
Edited by KeithbagVRS
Thanks Extreme3d
