Aftermarket Steering Wheel
Hi all,
Just wondering does antone have an aftermarket steering wheel on that can point me in the right direction,
So I have an OMP steering wheel with quick release boss kit ( already Fitted when I got the car) the air bag light is on and the horn isnt connected from what I can make out when you connect horn its on constant so im assuming its wired wrong also what do I need or how do I go about getting this air bag light off,
These are just niggly problems that are getting to me now im a bit OCD and want the car in the best possible condition before I start adding extra mods,
Thanks in advance,
either squash the airbag led light or fit a airbag steering wheel and reset light
Hi all,
Just wondering does anyone have an aftermarket steering wheel on that can point me in the right direction,
It will point you in the right direction if you turn it the right way :D
Cheers lads Ill look into getting the resistor,
Cheers lee :D
Don't forget for the MOT any airbag fitted as original equipment must now be present to pass the MOT, its now no longer simply the case of having no airbag light. With an aftermarket wheel it's quiet obvious that the drivers airbag is missing, especially given that all cars made after a certain date requires them to be fitted.
Supplementary restraints
The vehicle will fail the test if any airbag fitted as original equipment is obviously missing or defective.
A seatbelt pre-tensioner fitted as original equipment but missing or that has obviously deployed will be a reason for failure.
Seatbelt load limiters that are missing where fitted as standard or folding webbing type limiters that have obviously deployed are also reasons for failure.
The vehicle will also fail if a Supplementary Restraint System (SRS) malfunction indicator lamp indicates a system malfunction.
Thanks for the heads up mate ill get on the hunt for a standard steering wheel for the MOT, I hate the fact that they change the laws all the dam time with stuff like this its stupid, it should be optional weather a driver has an airbag in my opinion
