stream audio system
I've just found that I have an aux setting does this mean if I get the correct cable I could connect a usb to my system?
Aux on the Stream is a 3.5mm audio jack in, and that's only on the Stream MP3.
you couldnt connect a usb to ANY aux. The aux socket is dumb and simply plays what is fed into it, a usb stick is simply a storage device so it wont send any audio signal to the headunit
Where do I plug in the 3.5mm audio lead?
If your car came with a stream MP3, the aux connection port will be in the jumbo box.
I just have the basic stream unit but It does have an aux. How do I find the input on the stereo?
There won't be one. If it's the non-mp3 stream there is an aux option on the menu, but there isn't a plug in the car.
You'll have to use an emulator that replaces the CD changer to add an aux in.
