One button opening
Hi guys have borrowed my mates hex can vcds lead and want to set up the one button opening in the remotes, from what I can gather it's a code rather than ticking a box?
I did it on my Passat but can't figure it out on this mk2 octavia
Any help appreciated thanks
Matt
You want to deactivate selective unlocking?
Go to address 46 convienience control module and open coding.
save the coding to a note document if you mess up.
open up coding helper and search through for "single door unlock" then untick the box.
close the helper and the new code will be placed in the box.
click do it.
Once the coding is excepted exit the module and try it out.
Some high spec modules can turn the function on or off using the mfd and MFSW controls.
Brill thanks mate will give that a try tomorrow
Matt
