ARP Diff/LSD bolt kit 204-3002 02J/02A/02S/02R boxes
Blurb shamelessly robbed from somewhere else:
Uprated ARP Differential / LSD Bolt Kit
These Uprated ARP LSD bolts can be used for the Stock Diff and most Uprated LSD such as the Peloquin / Quaife
These bolts are only to be used with the 02A / 02J 5 Speed Gearbox, as well as the 02R, 02J-B and 02S Gearboxes
The 02R 5 Speed Gearbox is found in the Seat Ibiza Mk4 and Polo GTi Models
The 02J-B (5 Speed) & 02S (6 Speed) Gearbox is found in the Mk5 Golf Platform vehicles such as the VW Jetta, Audi A3, Seat Leon and Skoda Octavia 1.9 TDi
These ARP Bolts will only fit the 11.1mm crown wheel for the 02J / 02A / 02S / 02R
Please note that some 02S / 02R Gearboxes have a 12.1mm Crown Wheel and these CANNOT be used for those models
12x ARP LSD bolts
1x Assembly Lubricant
The 12-point nuts rated at 180,000 psi or better
The threads on these bolts are heat treated and then rolled for the best quality threads to ensure more accurate torques without binding
ARP Part Number
204-3002  /  204 3002  /  2043002
VW Part Number
02A498088A  /  02A498088 A  /  02A 498 088 A
Brand new unopened sealed in packet. Normally £60+P&P, £45 delivered :)
Bumpy before ebay :)
Guest
