Eibach springs - will this fit?
Going through a large pile of part from previous jobs, I've got a set of springs from a VW polo 9n3
Part numbers.
Rear:
Eibach Z/X - 118500801HA
Front:
Eibach Z/U - 111501402VA
Any idea what model they for, I've checked websites but had no luck and have a headache now being lazy.
Thanks!
Strange rears will fit but fronts won't!
Thanks for searching.
Edit; although both say estate also!
You're right, it's a weird mix and no mistake, the fronts would probably physically fit ok but would be underrated for the weight of the PD engine.
Edit: They're a full set for a an Audi A1 or a Fabia Mk2 Hatch.
Edited by sepulchrave
Will chance them on the 1.2 petrol model then, they are only a 20mm drop so perfect for what I want.
Will see if they look the same and fit safely and go from there then,
Thanks again.
Thanks again.
Give it a go, as long as they seat perfectly they should be fine.
