Retrofit Columbus to 2012 fl
Is it plug and play and what cableing if any req.d
Edited by heavyoil
Sort of.
Straight physical swap, but you'll need to add a PS antenna (should be supplied with the Columbus) and probably a new fascia (unless what you already have fitted is the same shape cutout).
Then some VCDS coding to get it all working correctly.
That's it.
Less than hour to do it all.
