possible to retrofit original DRL ?
i do not mean the tacky halford led strips
i would like to fit the lower front fogs with the DRL
i would not be wiring the fogs up but would like the incorporated drls to be powered
is it possible
i understand this is the fabia not roomster forum but the DNA at the front end is the same and a more likely mod a fabia owner would have done
You already have the daytime running lights no? Why not change your yellow bulbs to Cree LED?
Sorry that's the lenses I want to fit I only have grIlles atm
I don't know if it can be done easily, speak to an auto electrician for advice on what the job entails then if possible DIY.
Why would you not wire the fogs in if you are going to the trouble of doing the DRLs? If you are able to do one I would do the other while you're there.
Just save the hasslw of new switch etc mainly
Plus I don't think In nearly 25 years of driving I have ever used my front fogs
Not easy, its been looked into before. There is no loom behind the bumper which simply connects on.
It needs to be wired all the way back, and youd want the switch which goes next to the fuses too ofc.
Not really worth it imo.
Damn worth a thought though
