flashing light and beep
any idea want flashing light is and beeps on dash on clock its same icon that comes on that uses hand brake
Worn brake pads?
Low brake fluid warning?
Handbrake left on whilst driving?
According to the manual there is a separate warning for the brake pads...
The handbrake light is used to signal that either the brake fluid level is low or if accompanied by a beep means you have left the handbrake on a notch...
looks like 2nd one in pic handbrake is not left on any clicks I will look to see if brake fluid level is low
the fluid level is ok,
its ok for about 3 miles then you get a few loud beebs then the handbrake icon flashers all the time till engine turns off drive away 10 mins later same down road 3 miles beeb lol
  • 2 years later...
brake fluid full ,all pads done , light works as it should hand brake on and off  ok ,  i drive off sometimes it will try to go limp mode then the light starts flashing 3 bleeps then its ok ,sometimes i have to stop  because no 3 bleeps and stays in limp ,restart drive 3 bleeps flashing light then ok can drive normally  intermittent ,dint do it for 3 days then started again today ?
PS It is the dsg Automatic, if that makes a difference ? When i say limp mode i am  assuming ? it goes from 1st gear & tries  to go into 2nd  but jumps back to 1st
