Octavia vRS Xtreme Alloys Cleans
Hi Guys,
Do I need to use an acid free cleaner on these?
Thanks in advance.
Acid Free Cleaners are always better
Have a look here and take your choice:
http://www.cleanyourcar.co.uk/wheels-and-tyres/cat_7.html
We all have our favourites Mine is WW Hot Wheels as a Iron remover and Power Maxed Acid Free Wheel Cleaner ...Primarily on Clients' cars
So have a good read and choose one..Most do a good job
Golden rule...Wash them regularly...at least weekly...Apply a good sealant and you will rarely need an Alloy Wheel cleaner
Just be careful though, acid free normally means caustic which is just as destructive. PH neutral is a good phrase to look out for.
As Chris says, use a decent wheel sealant and you'll only need normal shampoo to clean. I use wheel cleaner once every couple of months if that.
Just obtained a set of used alloys I'm gonna use for winters, is CC Platinum, still the best choice?
Power maxed wheel cleaner is very good stuff, I was gonna do a few pics of before and after when I've cleaned the above up.
Edited by Thisday
Would you wash your cars paintwork in acid?
All alloys (unless they are bare polished alloy) have a clear coat lacquer on them... just like the paintwork, so treat them the same.
Prevention is always the answer though so a decent sealant / wax (FK1000P is my choice) will make cleaning them so much easier.
CC Platinum is one of the Ceramic type sealants that I have used
There are others ...but its so easy to use...its one I thoroughly recommend
I'll probably get that one thanks Chris, do you know the best places to get it from as I might grab a few other bits at the same time.
Would you bother with 2 coats?
Cheers guys, planning on a full clean this weekend.
