Rear damper console - snapped nut
Hi,
I was trying to get the rear damper off on my Ocatvia 1 wagon, however during the process one of the bolts was quite hard to loosen and suddenly the nut (I presume) on the other side broke loose.
So now I have a bolt which I cannot loosen or tighten as I cannot get to the other side. The bolts are no1 on the image.
Any suggestions on what to do ?
Think your only option is to cut it off and then weld a nut back in somehow when you re-install.
